TED 20 Wiring
Don
02-18-2001 15:22:41
I have got a TED 20 with a reconditioned lucas dynamo and lucas regulator box i am currently in the process of rewiring the tractor and need some help identifying which wires go to the dynamo. There are two spade connectors on the lucas dynamo, one large with a red plastic `tag` attached and one small, what i need to know is which ones go to which terminals on the regulator as neither are appear to be labelled on the dynamo. Thanks
pete tatham
02-25-2001 01:13:55
 Re: TED 20 Wiring in reply to Don, 02-18-2001 15:22:41
Don, wire, (yellow on original wiring harness) should go from large dynamo terminal to terminal marked D on control box. Thinner wire, runs from small dynamo terminal to terminal marked F on control box.
Hope this helps, Pete
pete tatham
02-25-2001 01:12:47
