Simple Question
Lanse
09-17-2007 16:26:01
My Neighbor has a TO20, and there is what appers to be a 5 or S as one of the gears. The shifter wont go up in there though. Anyone know what it is? I know this is a dumb question and could probabally answer it myself if it were a Farmsome.
rusty nut
09-19-2007 14:30:15
 Re: Simple Question in reply to Lanse, 09-17-2007 16:26:01
if its worn like mine you don't even have to pull up on the shifter,it will just go right to it.
Eoin
09-18-2007 01:50:22
I am not by any means an expert but here is my 2 cents - Is there a 1" dia brass button to the RH side of the tractor? (located where the transmission housing is connected/bolted to the rear section - more or less in line with the front of the seat)If so, that button must be pushed in to allow you to put the stick into "S" It is a safety feature to prevent you putting it into "S" while the tractor is already running. When the stick is in "S" the starter motor in engaged by a series of levers and rods. Please note - the stick will not automatically dis-engage out of "S" (start)when the tractor is started, you must manually dis-engage. Hope this helps. Eoin.
John (UK)
09-18-2007 07:52:33
 Re: Simple Question in reply to Eoin, 09-18-2007 01:50:22
That is only fitted to the TEF Diesel which was not available in the USA
Jeff-oh
09-18-2007 05:40:09
Eoin,
Where are you located? I am assuming Europe. I have never seen this brass button on the early TE/TEA or and TO tractors.
Perhaps it is a feature only on specific models. What tractors have you seen this on.
This sounds interesting can you provide more information?
John (UK)
09-18-2007 07:54:09
 Re: Simple Question in reply to Jeff-oh, 09-18-2007 05:40:09
It is fitted only on the TEF which is a Diesel model and it was never sold in the USA
Jeff-oh
09-18-2007 11:44:23
 Thanks John in reply to John (UK), 09-18-2007 07:54:09
Thanks John
speasb
09-17-2007 16:30:52
The "S" position engages the starter. You have to pull up on the shifter to get it into the position. However, someone may have bypassed this and rigged up a different starting method.
Mark from the fort
09-17-2007 18:04:23
 Re: Simple Question in reply to speasb, 09-17-2007 16:30:52
Yup, pull up on shifter,--be prepared though-when you push it into position it will engage starter and try to start. Pretty cool. On my 30, I also have to lift up to get her into "R".
