Putting in a Temp Guage on T-20.
Jeff-oh
09-17-2007 14:25:10
I have been fussing with putting in a temperature gauge on my TE-20. The issue I have is all the Temp guage fittings are too big for my port.
What has any onle else done? I am about the pull it off, redrill and tap to new thread size. It looks like I am off by a 1/16" or so.
Does anyone know the port size?
Jeff
gshadel
09-18-2007 09:38:14
 Re: Putting in a Temp Guage on T-20. in reply to Jeff-oh, 09-17-2007 14:25:10
Jeff, I wonder if it is possible that port on the coolant manifold is different between the TE & TO-20's, even though both are Z120 engines? If that is the case, I'm wondering if you found a TO-20 coolant manifold on Ebay, etc., that might solve your problem? I had no trouble installing the standard capillary bulb & threaded jamb nut that came with the temp. gauge I bought at TSC. I installed a gauge that was listed for a Ford NAA/600/Jubilee on my TO-20 a couple years back. It was a perfect fit, both length of capillary tubing & the bulb/jamb nut. No mod's necessary. I've seen those generic automotive temp. gauge kits that all the parts stores sell, that have several adapters, etc. and a fairly long capillary tubing. If that's what you using, check out the gauges at TSC.
George
Jeff-oh
09-18-2007 11:48:04
 Re: Putting in a Temp Guage on T-20. in reply to gshadel, 09-18-2007 09:38:14
I have an Agco Heritage line Temp Gauge. The Fitting the bulb slips into (Jam nut?) is a smige too big. The TO-20's I saw at Dover, Oh last month also had a similar size.
I think I could Re-drill and re-tap with no problem. I have seen the TSC gauges but did not get one.
Jeff
