TE20 clutch
Jim
02-18-2001 12:13:16
Will some kind fergusen owner please consult their TE20 manual and imform me of the correct clearence between the clutch plate and the presure plate. Pretty please!, I can't bring myself to rebuild my TED20 without knowing the clearence is correct. Any figures would be much appreciated.
Thanks again
Jim
wes mo.
02-18-2001 16:27:50
 Re: TE20 clutch in reply to Jim, 02-18-2001 12:13:16
T`````````he adjustment are set so the bearing contact surface of the levers are 1@15/16 from face of the flywheel.
wes mo.
02-18-2001 16:27:15
Rob
02-18-2001 14:26:00
All i`ve got is pedal adjustment which is taken fron the upper side of the clutch pedal and the underside of the foot rest bracket. there should be 3/8" or 9.5 mm play before the release bearing begins to contact the clutch
