Year of tractor
Herb Brady
09-11-2007 15:43:04
If I read the number correctly it is a 1950. If I am wrong would somebody correct Me. the serial number is 122729
John (UK)
09-12-2007 07:16:48
 Re: Year of tractor in reply to Herb Brady, 09-11-2007 15:43:04
Would you like to check your serial number again and give the prefix letters as the number you gave does not match up to a TO20, it could be a TO30. Check the Engine plate that is on the Block between the coil and the Distributor, if it has a prefix of Z120 it is a TO20 if it is Z129 it is a TO30...John
Bob (Aust)
09-12-2007 02:46:15
According to the Serial Numbers it does not appear to be a TO20 but a TO30, but some of the other guys here could give you far better advice than me.
Good luck!
Herb Brady
09-11-2007 17:38:08
it is a to 20 sorry i didnt put that down
Bob (Aust)
09-11-2007 15:52:26
Herb. It helps if you give the tractor model or serial number prefix....
If it is a TEA20 (Standard engine) it is a 1950 model.
If it is a TO30 (Continental engine) it is a 1953 model.
Bob (Aust)
09-12-2007 02:48:02
 Re: Year of tractor in reply to Bob (Aust), 09-11-2007 15:52:26
Herb, what is the engine serial number prefix?
Z120 or Z129?
