tae rear main
doug stevenett
09-11-2007 14:37:20
I need to change my rear main seal on my 1950 tae ,made in england tractor.Can i remove bearing cap and push new seal in?If i can what torque are the main caps retorqued at? Please reply
Doug Stevenett
John (UK)
09-12-2007 06:56:31
 Re: tae rear main in reply to doug stevenett, 09-11-2007 14:37:20
You have to split the Tractor (TEA) to do that and remove the Flywheel as there are two plates holding the seal in place.Remove the oil pan and then you can get at it. If the oil pressure is a little on the low side now is the time to replace the rotors in the Oil Pump, it will make a big difference to the pressure. You will need the info on how to reset the Engine Governor if you take the engine out. If you need the info on how to do ALL this work, then email me and ask me for it...John
