Steering bushings
John
08-19-1999 12:17:01
Has anyone worked on their steering and replaced the bushings. I need to fix mine and any info would help. Is there a place you can get replacements or anywhere you can find the specs of the outer and inner bushings to make new ones.
Paul
08-19-1999 17:39:57
 Re: Steering bushings in reply to John, 08-19-1999 12:17:01
John - Outer bushings are 1-5/16 x 1-7/16 x 1-13/64. The inner bushing is 1-1/8 x 1-7/16 x 1-1/8. Try and bearing house and see how close you can get. You may have to ream or shorten the length if you can get the OD to spec.
Good luck. Paul
