PRESSURE WASHER/ SANDBLASTER
Frank Biscardi
02-15-2001 10:20:06
Folks,
I am not really pleased with the thought of sandblasting because of the dusts/risks. I have heard that there are attachments for a pressure washer so you can sandblast wet with them. Have you all ever tried this? DOes it work? Where can you get one?
Thanks
Frank
rhudson
02-16-2001 11:58:08
 Re: PRESSURE WASHER/ SANDBLASTER in reply to Frank Biscardi, 02-15-2001 10:20:06
Frank, i got my wetblaster from a local Lowes store, (building supplies for yuppies). My washer is 2000psi and i am not happy with its performence as a wetblaster. i have been told it works great at 3500psi. i glass bead blast anything that will go into my cabinet. following advice given on this board, i am backing back from blasting tractor. i'm going the stripper method.
Frank Biscardi
02-15-2001 11:57:45
Please pardon the caps.
Frank
Joe ferguson
02-15-2001 13:57:43
 Re: Re: PRESSURE WASHER/ SANDBLASTER in reply to Frank Biscardi, 02-15-2001 11:57:45
Hi Frank
Sandblasing whole tractor is not recomended
Or on other mechanics
Because pressurized sand will be introduced in bearings shafts engine and all openings and will sand all moving parts in the future causing premature worn.
You may remove wheels fenders and hood and sandblast and paint separate and away from the tractor.
Hope it helps
Joe Ferguson
Frank Biscardi
02-15-2001 16:04:35
 Re: Re: Re: PRESSURE WASHER/ SANDBLASTER in reply to Joe ferguson, 02-15-2001 13:57:43
Joe,
What is the best way to do the transmission housing, etc before painting? Will a wirebrush on a drill do it?
Thanks Frank
Dave
02-15-2001 18:35:22
 Re: Re: Re: Re: PRESSURE WASHER/ SANDBLASTER in reply to Frank Biscardi, 02-15-2001 16:04:35
I brushed paint stripper on mine, brushed it with a wire brush then power washed it before the stripper dried. Two times like this gave bare iron, ready for primer
Dave
Joe Ferguson
02-15-2001 17:56:26
Hi Frank
If a pressure washer is available you can put standard engine washing soap this will remove grease dirt and paint chips. When dry you can use sandpaper disc on a drill or buffer.
Hope it helps
Joe Ferguson
mark
02-15-2001 14:05:07
I wet sand blaster mine about 6yr ago and I have yet to have any problem with sand .
You need a pressure washer that is 2000psi or better.you can get the sandblaster for pressure washer out of the nothern catloge
