Hydraulic Lift Cover
greenbank
08-19-2007 00:48:06
I'd like to remove the control quadrant for replating...is this worthwhile? I'm not going to fool with anything else in the hydraulics if I can avoid it. From what I can see, I need to remove the small cover and standpipe and then remove the main cover and setscrew for the quadrant.
I have the manual, and that's all I can see that needs to be done. Is that right?
(I'm thinking of having the quadrant parts plated in hard chrome, which would be bright but matte in finish and much harder wearing than the original plating. Opinions?)
I don't need to get into the actual hydraulics just now -- that rebuild can wait for another few years, they work OK as they are.
John (UK)
08-19-2007 06:27:18
 Re: Hydraulic Lift Cover in reply to greenbank, 08-19-2007 00:48:06
It helps when you say what tractor you have. I think that possibly you have a TO35 from the rough description you give. If you need the information for removing the Top Cover and for resetting the control linkage then email me at:-
fergusontractors(at)tiscali.co.uk
There will be some wear in there and it is quite easy to set that system so you should consider doing it while you are doing the Quadrant...John
greenbank
08-19-2007 07:19:47
 Re: Hydraulic Lift Cover in reply to John (UK), 08-19-2007 06:27:18
Sorry, John, it is a TO35. I'll drop you an email. Thanks.
