TO30 6-volt not charging
Tom H
02-12-2001 15:26:00
1954 Ferguson TO30 in great shape and has been running and charging perfect untill yesterday.
Original six volt positive ground generator setup.
When I ran it to grade driveway it wasn't charging so I stop and looked at the connections which all looked good. Looking at ammeter when I restarted it the ammeter read positive as the engine hit but went to zero after revs got over about 700 rpm. Seems like low voltage coil on regulater OK but high voltage out? I don't know. Anyone out there know where and how to look first?
Fred OH
02-14-2001 10:08:58
 Re: TO30 6-volt not charging in reply to Tom H , 02-12-2001 15:26:00
Sometimes you can take a hammer handle and tap on the generator and see if it is the brushes in it that are not seating and then do same for the regulator. Be surprised what a little thump therapy will learn you if you got any luck at all. L8R----Fred OH
Jim
02-13-2001 10:24:00
My first guess would be the generator. You should be able to take it off and have it tested at a local auto parts store. You might have to call around to find one to test it.
