To30 excessive crank thrust bearing tolerance
tom
02-11-2001 19:11:14
what are the options for remedying excessively worn thrust bearing and or crankshaft? Ive heard oversize thrust bearings are available. Any info? Tractor is about to be overhauled anyway.
dennis
02-12-2001 16:08:38
 Re: to30 excessive crank thrust bearing tolerance in reply to tom, 02-11-2001 19:11:14
the ohaul kit comes with spacers for the thrust adjustment. Also the front pulley presses onto the shaft, pressing against the washers which effectively adjusts the shaft endplay. The tighter you press the pulley, the tighter the endplay.
