to35 hydrolics
James Cox
08-03-2007 19:59:35
when my tractor is first started the 3pt works fine but as it gets hot it will not lift or hold also when you turn off the engine lift gos down even when first started.
John (UK)
08-07-2007 11:22:59
 Re: to35 hydrolics in reply to James Cox, 08-03-2007 19:59:35
On the TO35 and the other 35's the valves in the side chambers get worn as the pressure is on them all the time, there is no check valve on this system like the earlier one. So pressure will leak through the valves, the pistons wear quite badly and pressure will leak through them and the Control Valve has a series of washers to separate the suction and pressure and these wear and allow the pressure to escape. Really when it gets like that you nearly always have to overhaul the Pump. If you want more info about all this, email me at:- fergusontractors(at)tiscali.co.uk
and ask me again in that email and I will send you the Info you need....John
Jerry/MT
08-03-2007 21:11:45
These problems are usually caused by a leaking cylinder( worn rings or cracked cylinder) or a leaking supply tube to the cylinder. Pull off the righ side access cover, start the engine, make sure the pump is engaged and look up to where the cylinder is located. If you see any more leakage then a few drops that's your problem.DO NOT, UNDER ANY CIRCUSTANCES, STICK YOUR HANDS INTO THE HYDRAULIC COMPARTMENT WITH THE ENGINE RUNNING!
Sometimes a relief valve sticks open. In that case you see a bunch of turbulence in the oil and it'll be pretty noisey.
