What does the light on the dash of a TE20 show?
Mike
02-11-2001 12:42:43
Does anyone know what the small light by the air intake on the dash of a TE20 display? My one does not work and never has. There appear to be several thick wires running into it however so I was wondering if it indicates anything of importance?, is it worth replacing?, thanks.
Joe in NY
02-11-2001 17:19:14
 Re: What does the light on the dash of a TE20 show? in reply to Mike, 02-11-2001 12:42:43
Mike,
My appology. Joe Ferguson is correct. I have my ignition system modified and I am using the light as an indicator lamp. Told you I was a dummy.
Sorry to mislead you.
Thanks Mr. Ferguson.
Good luck,
Joe
Joe Ferguson
02-11-2001 13:24:23
Hi mike
This is the charging indicator same as in
car dash board.
This light indicated if the generator is charging
or not. Assuming that tractor is in original state
with a generator.
When you put ingnition switch on...it glow
when engine is running it is not supposed to glow.
it is normal that it glow a idle RPM because the generator is not turning fast enough
to charge.
Good luck
Joe ferguson
Joe in NY
02-11-2001 13:08:48
Mike,
The light gives you an indication that the key is in the on position. I replaced mine because I'm a dummy and it helps remind me to turn it to the on position when I keep crank'n and crank"n and she don't start. I picked up a 12volt neon lamp (available in 6volt too) from radio shack and replaced the whole unit because like yours it was missing and had corroded badly.It's a sealed unit and good for thousands of hours so it should outlast me. The wires can be wire nutted together instead of going to a screw terminal.
Good luck,
Joe
