TO20 wiring diagram.
Rob in Al.
07-30-2007 12:55:32
I"ve looked through many diagrams but haven"t found for my tractor. I just bought a new ampmeter and want to be sure I"ve got everything wired properly. I need a diagram for a 12V system with only 1 wire from the alternator. Everything I"ve found shows a 4 prong regulator. Is there a diagram that shows just wiring for 1 wire alt., starter, starter switch, ampmeter, distributor, coil and lights, if so where do I find it.
Thanks,
John (UK)
07-31-2007 07:56:01
 Re: TO20 wiring diagram. in reply to Rob in Al., 07-30-2007 12:55:32
If you want a wiring diagram email me at:-
fergusontractors(at)tiscali.co.uk
just tell me again what you need in your email and I will send it....John
john[mo]
07-30-2007 14:52:35
if you are running a 1 wire just run the wire from the alternator to the ammeter and then to the battery. if you hook the wires up wrong on the ammeter it will show discharge when charging. just switch the wires.
