wrong radiator
Danny /ks
07-27-2007 15:34:25
hey guys,Im in the process of resurecting a 1948 te 20. its coming together thanks to this forum. the problem now is I have ordered two radiator caps from this site and they are not even close. more investigating shows I have a non pressureised radiator. this has been working is it safe,ive never used more than 30 min at one time yet. installing new temp guage tomorrow.any help would be great. Thanks Danny
Hills of TN
07-28-2007 06:15:18
 Re: wrong radiator in reply to Danny /ks, 07-27-2007 15:34:25
Don"t know about the non-pressurized part, but I had the same problem with our TE20. The one ordered from YT was much too small. John(UK)says the TEA and the TE should be the same - I ordered the one for the TEA from YT and it was a perfect fit. Just be sure you have the original TE20 radiator and not a replacement. Hope that helps.
danny /ks
07-28-2007 08:36:42
 Re: wrong radiator in reply to Hills of TN, 07-28-2007 06:15:18
The cap on my radiator is huge and says water on it.Looks like radiator came off an old oliver or something. Im just not sure if it will work correctly, or if te20 must te pressurised.The person I purchased tractor from used it for at least 25 years.Just dont want to hurt anything.Thanks Danny
John (UK)
07-29-2007 08:25:14
 Re: wrong radiator in reply to danny /ks, 07-28-2007 08:36:42
The cooling system on your tractor should be pressurised to 4lbs psi. The reason they pressurise the cooling is that it raises the boiling temperature of the water so if you use yours unpressurised it will quite quickly start boiling. In very hot conditions you can fit a 7lbs psi radiator cap to lift the boiling temperature a bit more. You must check the ignition timing and the carburettor settings that they aren't too weak or retarded before you fit this cap though.
Danny /KS
07-30-2007 14:19:36
 Re: wrong radiator in reply to John (UK), 07-29-2007 08:25:14
Thanks John(UK) and every one else for your help.Looks like I will be getting a new radiator,then moving on to the trans and hydrolics. Thanks again. Danny.
Lance J.
07-27-2007 18:44:19
Danny, the man you need to talk to is John(UK), a regular contributor to this forum and the TE series guru. His email is [email protected].
Bob (Aust)
07-27-2007 19:40:22
 Re: wrong radiator in reply to Lance J., 07-27-2007 18:44:19
If it is the same as the TEA20, 4 psi for light work, 7 psi for heavy work. John (UK) will know!
