engine relief valve
charger
07-26-2007 02:56:55
I've replaced front crank seal but not rear yet. Why? because sometimes on identical days, temp, type of work you name it,it wont leak hardly worth mentioning. Other times under exactly the same conditions it will spue near a solid stream and the new front one will sweat some to on those times. Could this be the relief valve? How does one check? Thankyou
gshadel
07-26-2007 05:45:14
 Re: engine relief valve in reply to charger, 07-26-2007 02:56:55
Charger, possible... but doubtful on the relief valve sticking and causing over-pressure. What engine are we talking about a Z120 or Z129? Oil flow is a little different between those two. You would probably have to have some clogging in other areas to really overpressure the crank bearings. What does your oil pressure gauge say? Do you have one? On your rear, it may be possible you have a bad front tranny seal also? It all leaks out the same cotter pin hole, and your GL-1 tranny oil is gonna look like motor oil. Doing up & down hills can make that tranny seal leak more/less at depending which way your going.
But, if you decide to get into it, the relief valve is easy to get at, once the oil pan is dropped.
George
