ferguson to 30 air cleaner cleaning the inside
john fleming
07-23-2007 17:05:36
Is there a way to clean the inside to these air cleaners with out doing damageing the filter media.I believe I have narrowed my over choking condition to this.have done a valve job,timing,ignition rebuild,including plugs,carb.rebuilt twice good comp.JUST BLACK SOOTY SMOKE. in combustion chambers,exhaust ports,and plugs no missing to speak of just that choking sound and smoke. thanks big john
John_UK
07-24-2007 05:47:24
 Re: ferguson to 30 air cleaner cleaning the inside in reply to john fleming, 07-23-2007 17:05:36
You need to leave it to soak in kerosene or gas as someone has already said, leave it for 24 hours and allow to drain and dry thoroughly after swilling it around in the gas. Check if the wire mesh inside is still ok as they do rust away due to moisture in the air, if it has done this you can get a refill kit from Sparex, part S43231 for it, you have to open the casing to do it and then weld it again.
Jim Gorter
07-23-2007 17:43:52
Cleaning with Stoddard Solvent from a parts washer or Kerosene. use a long bottle brush to clean inlet pipe. Have you disconnected the filter to determine if it is the restriction? Also, remember to clean out cup and refill with engine oil to line on cup. Good Luck, Jim.
rusty nut
07-23-2007 17:29:45
soak it in kerosene
