to 20 pto seal
jim r
07-23-2007 16:43:27
orderd seal looks like it goes betwean dust cover andv bearing also three point hitch arms not raising has oil no book on it yet have any ideas
Terry G
07-24-2007 07:21:03
 Re: to 20 pto seal in reply to jim r, 07-23-2007 16:43:27
third party image
If it is an aftermarket shaft and housing then the bearing may go in first then the retaining clip then the seal. I think the original housings had a retaining clip on each side of the bearing. Here is a picture of my aftermarket shaft.
jim r
07-24-2007 16:36:35
 Re: to 20 pto seal in reply to Terry G, 07-24-2007 07:21:03
thank you got it replaced the dust guard was in to my seal did not know what i was looking at until i saw the picture
John_UK
07-24-2007 05:53:27
The seal goes in the PTO housing first, then the bearing then the circlip to hold it all together. Make sure the sleeve on the PTO shaft the seal runs on is not marked or it will damage the seal again. Did you put the PTO in gear or the Hydraulics will not work, if you did then the Control Valve may be stuck. If you need more info on what to do about that email me at:-
fergusontractors(at)tiscali.co.uk
tell me what you want to know and I will send it. John
John (UK)
07-28-2007 04:55:00
 Re: to 20 pto seal in reply to John_UK, 07-24-2007 05:53:27
You will have to email me at the address I have given in the earlier email so I have your address to which I can send the information, I can't send it on here....John
jim r
07-27-2007 14:34:36
thank for your help i stll can not get lift arms to raise
