to-30 starter problem
Ian Walker
07-22-2007 14:32:15
I am having an ongoing problem breaking the part of the starter that bolts to the block. My starter guy said it has a tendancy to break if I try to start it while rolling backwards. I have broken 3 of them while completely stopped. It seems to be at random times, and it's getting expensive and frustrating. Please help!!!
John_UK
07-23-2007 11:20:31
 Re: to-30 starter problem in reply to Ian Walker, 07-22-2007 14:32:15
You should check that you have no end float in the Crankshaft as that can cause the Ring Gear to strike the Nosecone too. You have very little clearance between the Ring Gear and the Nosecone and in some instances the Starter needs shimming onto the Block to get this clearance correct.
dfitch
07-23-2007 01:26:08
I had 3 break in a short period of time last year but have not had any more trouble with it since I replaced the ring gear on the flywheel.
Not sure but I think some of the early to30's were made with to20 flywheels which did not had the lip on the flywheel to hold the ring gear in place. Suggest you remove the cover behind the oil pan and see if the ring gear has been pushed back. Mine was pushed back far enough on one side that the starter drive could not reach the ring gear. If you find that you have that problem post back here, I have a fix for it.
IAN WALKER
07-22-2007 15:15:03
ACTUALLY I GUESS THE PROPER TERM IS THE NOSECONE, THE PART IS REMOVEABLE FROM THE STARTER ITSELF. SEEMS LIKE IT HAS TO BE GETTING SOME SIDEWAYS TORQUE OF SOME KIND. JUST WANTED TO BE MORE SPECIFIC
Jerry/MT
07-22-2007 17:01:41
 Re: to-30 starter problem in reply to IAN WALKER, 07-22-2007 15:15:03
Make sure that the thrust washer is on the shaft between the drive gear and the bushing in the nose piece. The part number, parts manual is 1 750 440 M1 "Washer, Thrust, Drive End".
I have a TO-30 with the origginal starter, and I have a 12 V electrical system.
IAN WALKER
07-22-2007 20:00:19
 Re: to-30 starter problem in reply to Jerry/MT, 07-22-2007 17:01:41
THANKS, I WILL LOOK, I DON"T THINK IT HAD A WASHER ON IT!
