The past several times I've run my TO, the ammeter would not show any charge for several minutes, but after driving around for a few minutes it would start to show a charge of a couple amps. The other day I was driving around for 5-6 minutes with 0 amps and decided I needed to figure out what the heck the problem was. I had an opportunity to practice what I preach for troubleshooting a 6V charging problem....Step one - When I crank the engine, the ammeter goes negative. I check the battery with my volt meter, engine running, 6.2V.... not charging, ammeter is probably working since it goes negative when I crank the engine and it definitely ain't charging. Step two- hook-up a jumper wire from ground (positive) to the F terminal on generator to bypass the regulator and force the generator to full output... still 6.2V, and 0 amps. Generator is not working. Step three - decided to clean all my connections & terminals on the regulator, generator, and ground strap to the dash and try again (probably wishful thinking). Did that, repeated step two, still no output from the generator. Step four - took-off the band on the generator so I could see the brushes and commutator. Brushes looked okay, commutator looked kind-of dirty. Also decided to clean the generator mounting bolts. (the generator is grounded to the engine block via the mounting bolts). Ran the engine and rubbed a stick with 220grit sandpaper on the commutator and shined it up to bright copper color, and blew out the debris with compressed air. Looked at my ammeter.... 10 amps! Volt check 7.2V Charging good now! While I was messing around in the generator, I decided to try moving my 3rd brush to increase the amp output. Since I installed front & rear lights, I discharge the battery when I run all three lights at the same time. After a few adjustments, I was able to get full output up from 12A to 18A when the F terminal is jumpered to ground. Now with the regulator running the generator, my ammeter still shows 1-2A with all my lights running. Cost to fix my 6V charging good as new - FREE! (except for the 1 piece of sandpaper) I might just keep this 6V system a while longer. I also brushed-up on my 3 brush generator knowledge a little bit. There are 2-3 good articles over on the left about that. George
