TO 20 Temp gage
Robert Barrett
07-13-2007 12:44:52
Im wanting to put a temp gage on my TO20 tractor, and the ONLY way i see i might can do this is to install it in the place where the Drain pitcock on the block is located. Need an opinion if this may work , or is too far from the head. Any help & info greatly appreciated.
Bob Barrett
Aiken SC
GrampaJack
07-13-2007 13:47:31
 Re: TO 20 Temp gage in reply to Robert Barrett, 07-13-2007 12:44:52
Look on the left side of the outlet to the top radiator hose. There should be a hole there with a pipe plug in it. You will probably need a fitting that is big enough for the sending unit to screw into. Mine works fine. Best Regards, Jack
Robert Barrett
07-13-2007 14:41:58
 Re: TO 20 Temp gage in reply to GrampaJack, 07-13-2007 13:47:31
yep ,Found the plug, Thanks everyone for the reply & help!
Bob Barrett
Aiken SC
