TO-35? How much will they lift on the 3 point?
Paul Kingsbury
07-08-2007 18:03:02
Hi guys, I have a TO-30 and I was wondering if the 35 will lift any more? If anyone has numbers on how much they will lift I would really appreciate it? Thanks, Paul
John (UK)
07-09-2007 12:53:11
 Re: TO-35? How much will they lift on the 3 point? in reply to Paul Kingsbury, 07-08-2007 18:03:02
The TO30 recommended max lift is 750/800 lbs at the end of the lower links of course the further the implement stands away from the tractor then the less it will lift. The TO35 will lift significantly more than this, a maximum of 1700lbs but for road work carrying an implement in Transport position it should be no more than 1270lbs and you may need front weights. The same applies to this tractor as well about the further the load is away from the tractor the less it will lift safely.
Paul Kingsbury
07-10-2007 21:27:17
 Re: TO-35? How much will they lift on the 3 point? in reply to John (UK), 07-09-2007 12:53:11
Thanks John, just what I wanted to know!
Paul
steveormary
07-08-2007 18:49:02
Paul,both tractors will lift more then what the front end will hold down. Probably 7-800#'s.
be careful and have fun.
steveormary
