to30 carb chokeshaft retainer spring?
rusty nut
07-05-2007 07:21:37
having trouble with spring,its the exterior spring on carb for the choke,went to ferguson dealer thet gave me spring that is for ford 9n,they think it is the same for ferguson,I put spring on but it seems like it is backwards,when you pull the choke knob it opens the flap in carb,when you push choke in it closes flap in carb,its backwards?also the way spring hooks up the choke shaft lever is in the down position instead of up,the springs do look alike as far as I can tell but the old spring broke so I don't know for sure,either I'm doing something wrong or I have the wrong spring?please help,its driving me nuts.
gshadel
07-06-2007 05:06:40
 Re: to30 carb chokeshaft retainer spring? in reply to rusty nut, 07-05-2007 07:21:37
Rusty, it's been quite a while since I tore into my carb, but you question sounds similar to a problem I had. I somehow installed the choke butterfly, spring etc. opposite of it's intended use, so it worked backwards. Looked fine, worked fine, just backwards. I didn't realize it until I was re-installing the carb and realized..... wait a minute.... that ain't right! Had to take the carb apart and change it.
George
