what year?
scott amirault
07-01-2007 16:53:56
i am new to this tractor stuff need some help with the year of my tractor.when i bought the tractor last year i was told it was a 1952 tea20 the serial # on the dash panel is missing.the engine serial# is s78421 is this a 80mm or 85mm bore.the numbers in front of the diff dip stick from bottom to top is 150 then stamped along side of those numbers is the #3.could anyone give me some info on this.thank you
John (UK)
07-02-2007 14:07:59
 Re: what year? in reply to scott amirault, 07-01-2007 16:53:56
Look at those numbers again, they should all be in a line, any to one side discount them. When you have worked out the date, the castings were usually used within about 4 - 6 weeks of that date
Bob (Aust)
07-02-2007 02:23:34
"..the numbers in front of the diff dip stick from bottom to top is 150.."
Casting date 1st May 1950. Sounds like a mid 1950 TEA20.
CENTAUR
07-01-2007 17:59:49
www.fergusonenthusiasts.com/ CENTAUR
