TE 20 dash
CPD Sarge
06-27-2007 16:16:52
Anybody have a good picture of what the original TE 20 dashboard area should look like or know of one online? Mine has been altered for a manual type starter switch, key switch and the choke rod is missing altogether. None of the manuals I have show the dash. I would like to restore it as original but don't have a clue what original looks like. Any help appreciated!
Matt Higgins
06-30-2007 06:09:14
 Re: TE 20 dash in reply to CPD Sarge, 06-27-2007 16:16:52
No problem Sarge - glad to be of help.
Matt
Matt Higgins
06-29-2007 09:23:14
third party image
Here's (hopefully) a picture of our TEA-20 dash while we had a lot of things off. Let me know if you need any better ones, and I'll take one next time I'm over there
matt
CPD Sarge
06-29-2007 19:11:17
 Re: TE 20 dash in reply to Matt Higgins, 06-29-2007 09:23:14
Hi Matt, Thanks, now it all makes sense! I had some kind of aftermarket ignition switch and knew it wasn't right! I appreciate the help. Regards, Sarge
CPD Sarge
06-29-2007 10:19:03
Thanks Matt. My dash seems to have a larger hole on the left hand side, it looks like the hole was stamped into the panel as the edges are bent toward the front of the tractor. Can you tell me where the key switch and the choke rod would go? Thanks again for the help!
Matt Higgins
06-29-2007 11:23:05
 Re: TE 20 dash in reply to CPD Sarge, 06-29-2007 10:19:03
Hi Sarge
Our ignition key goes through the round hole on the curved panel under the white faced gauge.
The choke goes up through the round hole on the right hand side curved panel (the top most hole of the three)
Hope that helps, Matt
