gshadel
06-26-2007 08:06:01
Re: TO20 engine rebuilt time in reply to FergFord, 06-23-2007 22:47:16
You really need your compression numbers to make the best decision. Speaking from experience here... A word of wisdom... try to decide up front the extent of your rebuild/replace job, rather than working into it one step at a time. There are quite a few kits available, from gasket sets, upper rebuild kits, lower rebuild kits, whole rebuild kits. The kits are all lower priced than buying the individual components. If you start out buying just a gasket set, and rings, then decide you need to rebuild the head, or replace a worn piston, you will get duplicate gaskets and pay more than getting one all inclusive kit. If you have the luxury of time, I recommend tearing into your TO to inspect the valves, guides, pull your piston(s), check for wear, then decide the extend of your repair, and order parts once. You can do ALL of that without splitting the tractor or pulling the engine. Also, if your TO was ever rebuilt before, you may have oversized pistons/sleeves. You will want to measure the piston to make sure you get the right size rings. Step#1 though is to make sure you have a Fergy reprint shop manual. The info in there will help you decide the extent of your repair work. George
