te20 oil line
john [mo]
06-20-2007 07:39:24
where can i get the oil line running from my oil gauge to the engine? can i just go buy tubing and normal compression fittings?
Bob (Aust)
06-22-2007 00:05:51
 Re: te20 oil line in reply to john [mo], 06-20-2007 07:39:24
I made mine up out of brass tube - forget the diameter, maybe 1/4 inch? - instead of the original steel tube (TEA20) which had rusted badly.
Sweated the banjo fitting off the old tube, cleaned the fitting up in a pedestal drill and silver soldered to the new tube. The guage end should be flared only - make sure there are no leaks at pressure after re-assembly.
I made my oil pressure guage tube longer than original and added a couple of coil loops to absorb any vibration.
And don't do what I did - make sure you put the guage nut on the tube BEFORE flaring the end!!
John (UK)
06-20-2007 11:21:08
As long as the fittings fit the engine and the oil pipe there is no reason not to do it, there is nothing special about it.
