Jim in OH
06-20-2007 11:53:28
Re: Crack Saga II in reply to Jerry/MT, 06-20-2007 10:21:25
As you know, the volumetric efficiency of this engine is probably 70% maybe less... so the effective combustion pressures while running fast are significantly lower than with a good breathing intake, so 9.4 is probably more equivalent to a nominal CR 7 at these higher speeds... but even at low speed and WOT, pump premium 93 octane is probably good to about 9.5 CR... and if that is was not good enough, I was going to start mixing in E85 (and enriching the mixture). Cooling might be an issue if I worked it that hard very long but thermal efficiency would have been actually better (higher CR), so the thermal losses are a lower percentage of the total (even though the totals would be up..) and with a good clean system, it should be okay. It was probably overdesigned to operate in a dirty and fouled environment anyway... The old auto systems that I have analyzed were typically double or triple the minimum clean requirement... Also, for daily use, I was not intending to push it that hard.. the extra HP was for the dyno numbers and probably a little tractor pulling.. Exhaust shouldn't be an issue.. 30-50% more volume is not a big deal (like it would be at the intake). The exhaust distance is short and I was going to use an straight large open vertical anyway... these are not tuned exhausts, although I was going to play with the length. The real problem is getting the air in, not out... and looking at the TO30 intake, most of the junk ahead of the carb can be bypassed or eliminated using a modern pleated paper element at the inlet... also the carb throat and immediately downstream is very small (not much more than 1 inch diameter), so could be greatly improved. Not much can be done with the valves, except a little lift (which I was not going to do), and not enough room for bigger valves but the ports are typically poorly matched to the intake so a little help here may mean much later.. It was going to be somewhat of an experimental undertaking to see what I could get out of it. Now I think I will just finish it with the stroked crank, put it on the dyno to get a real engine Hp, T vs rpm curve and call it quits... won't be stock Ferguson, but should be something to look at... I have a std crank too, and could get the "stock" numbers, but that means taking it apart twice and like I said.. I am losing interet.. "Stock" numbers wouldn't actually be stock anyway because the bore now is 3.375 compared to the stock 3.25 that is not available anymore.... Jim
