oil pressure sneaking up
mark from the f
06-15-2007 06:01:26
While running the rototiller on my 55 to35, I noticed the oil pressure needle going from "dead center"(normal) to once in while creeping toward the "high" side then dropping back down to dead center. not a constant thing, just once in a while. This tractor is all original--seems like if oil relief spring were getting weak, then this would result in "lower" oil pressure?
Have religiously changed oil and filter.
Think I need to look into oil pump rebuild?
Thanks, Mark
Jerry/MT
06-15-2007 09:32:48
 Re: oil pressure sneaking up in reply to mark from the fort, 06-15-2007 06:01:26
As Gerald says it could be the relief valve hanging up but once the tractor is at operating temperature, and you hold the rpm constant, it shouldn't cause the relief valve to want to change position. You could also have a crack or a leak in the suction tube to the pump.
Keep a close watch on your oil pressure and shut down if it drops below the recommended level.
Gerald J.
06-15-2007 07:24:16
Sounds like the oil pressure relief piston is hanging in its cylinder. Maybe from crud, maybe from vibration induced wear.
Gerald J.
