Adjusting wide front end, F40
jgn
06-13-2007 12:45:16
Anyone have experience(and tips) adjusting the wide front in from wider to narrower after it has been in the position VERY long? I got the nuts off the large Bolts in the axle but the bolts themselves do not budge. Sprayed it with penetrating oil and am waiting.....Thanks
Dan S (NY)
06-14-2007 09:18:37
 Re: Adjusting wide front end, F40 in reply to jgn, 06-13-2007 12:45:16
I had this problem with my MF50 which has the same front end as your F40. I did what Jim suggested and that worked on two of the bolts, but the other two wouldn�t budge. I finally got them to turn by using about 5 feet of leverage, and only then with difficulty. Had a friend use an air chisel on the end of the bolt while I turned them and that finally forced them out bit by bit. I had to buy some new bolts after that treatment. There was lots of dirt and rust packed in there holding it very tight. Good luck with yours and don�t give up!
Dan
Jim in OH
06-14-2007 05:30:25
Maybe a little late by now.. hope you have the bolts out, but if not, here is what I'd do... I'd get some additional nuts (same size), screw them about 80% on the bolts (do not expose the threads) and hit the end of the bolts on this nut covered end with a BIG hammer to break it loose.. It ruins the nuts (and not the bolt/threads).. Jim
