Timing marks
Henry
02-02-2001 12:08:23
Where do I find the timming marks on my TE20?
Tom B
02-02-2001 15:24:33
 Re: Timing marks in reply to Henry, 02-02-2001 12:08:23
If no marks are found there, according to book -
The Top Center point is when two punch marks on the flywheel are in register with identical punch marks on the flywheel housing starter motor mounting pad. In this case the marks cannot be seen until the starter motor is removed for the engine. My TE was like this.
On later TE's - the flywheels are stamped with a zero mark indicating top center with additional stamped lines from one to 30 degrees. these zero and degree lines index with a pointer at the flywheel inspection port which is located on the distributor side of the engine.
I can email you a page if you want.
TOm B
Topeka Ks
wes
02-02-2001 12:45:03
if your facing the front of the tractor it should be on the left front of the engine on timing cover in line of edge of balancer pulley if it has a fan shroud you have to remove it to see it.
