Marvel-Schebler TSX carb question
Gasoline Fumes
06-10-2007 02:54:16
third party image
Hi, I'm rebuilding a carb from a TO-30 and I have one passage that either goes nowhere or is very plugged. Should this port go somewhere?
Thanks.
http://i12.tinypic.com/54jenhg.jpg
Gasoline Fumes
06-10-2007 19:34:40
 Re: Marvel-Schebler TSX carb question in reply to Gasoline Fumes, 06-10-2007 02:54:16
Thanks for the diagram! That's what I suspected, but it's so plugged up that it looks like a dead end. I just jammed a needle in there now and got it at least partially unplugged. Seeing how it necks down in the diagram really helped, I was trying to unplug it with a wire that was probably too thick. I'll squirt some more solvents down it and work it a little more. Thanks again!
Phil (NJ,AZ,SASK)_
06-10-2007 07:01:44
Thats the Primary idle Orifice, the one below is the secondary Idle Orifice. They are both connected (sourced)from the same passage.
JMHO
Phil(NJ,Az,Sask)
06-10-2007 10:55:21
 Re: Marvel-Schebler TSX carb question in reply to Phil (NJ,AZ,SASK)_, 06-10-2007 07:01:44
third party image
diagram
