TO-30 motor cracked
ratskinner
02-01-2001 13:36:45
My to-30 has water getting into the oil.so I pulled the head off and it has crack's in the block right between the cylinders on the opposite
side of the oil jacket.Would this let water into the oil?
Fred OH
02-06-2001 10:51:01
 Re: TO-30 motor cracked in reply to ratskinner, 02-01-2001 13:36:45
Try putting some stop-leak in the radiator and try not to worry about it too much. Sometimes this will get you by. L8R----Fred OH
JW
02-01-2001 15:14:35
this will not let water in your oil as long as the head gasket is good and sealed but you need to pull off your oil pan and look to see if the block is cracked on the bottom between cylinders if it is then you will have to get a new block or have this one pinned. JW
