Rebuild heads
Darrell
01-29-2001 20:29:27
I have a to 20 and would like the torque specs on the head. All so it has low oil preasure the main bearing looked good. I was going to rebuild the oil pump. With the rear seal leaking I was wondering if there was a speedy sleave you can intall on the crank shaft since there was some wear on the crank. thanks DC
dennis
01-31-2001 16:42:38
 Re: rebuild heads in reply to Darrell , 01-29-2001 20:29:27
the seal on the rear of the crankshaft requires you to split the engine from the tranny, and remove the flywheel to replace it.
