Parts Lists
toolman
05-31-2007 13:36:41
Started out going to replace the clutch on my Tea, once i got into the tear down the parts lists is growing by leaps and bounds.Best time to do it while it is all tore apart,think i best buy some lottery tickets.lol .What a wonderful little tractor though and the quality of craftsmanship back then is truly amazing, i had noticed that before when i replaced rear wheel seals.This is a working tractor and sure earns her keep so im taking my time and trying to do it all right.I thought they were supposed to be grey , mine has a lot of red under all that grease.
Jim W
06-01-2007 10:32:32
 Re: Parts Lists in reply to toolman, 05-31-2007 13:36:41
Toolman,
Let me know if you get stuck for parts; I have just about an entire transmission of spares leftover from making three tractors into two.
Jim
grandfatherjim at gmail dot com
(A very young grandfather mind you...)
toolman
06-03-2007 20:33:35
 Re: Parts Lists in reply to Jim W, 06-01-2007 10:32:32
Sorry Jim, i never caught your post until just now. Jim i think i have everything i need now, i need to go to a guys place this week just down the road a piece and see what he has but he thinks he has all i need, i,ll let you know if he doesn,t ok, thanks again , and again sorry i never replied sooner.
mike a. tenn.
05-31-2007 13:48:39
lots of "em got painted red fer some reason. my to 20 and 35 got painted red somewhere along the line. ..so you finally got yor fergie split huh? have any trouble? what are you plannin" on replacin"?
toolman
06-01-2007 08:59:22
 Re: Parts Lists in reply to mike a. tenn., 05-31-2007 13:48:39
Yup she is split Mike, no problems.What a mess though,clutch plate fell out in pieces,thowout bearing and bearing retainer was shot, one of the forks is bent,one spring laying in the bottom, pilot bearing never had much left.
Somebody had been in there before, whne i was taking the bolts out to split it all had a head of 11/16 except one 5/8, i found the other 11/16 done in the tranny bottom. What a mess there ball bearing tin etc. laying in the bottom.
Im going to need a imput shaft as well, splines where the bearing was sitting are wore down, tranny seal is leaking, need that,everything pretty much.
Always had troubles with that throwout (release) bearing now i know why, i have the correct one here and the one that was in there has a different part # and ends with a 14 , the one i have ends with a 16.
Mike , im going to start replacing parts at the front and work my way back to the clutch, steering,Axle pin, bushing, belts , well you get the idea.I,ll do the parts list this weekend and email it to Art, it will take about two weeks to get it here probably, but i got lots to do to keep me busy till then.Catch ya later buddy.
Bob (Aust)
05-31-2007 20:53:16
Red inside or outside?
The TEA20 was all over grey, however inside the castings - bell house, steeing column etc - they were painted with red protective paint.
toolman
06-01-2007 08:44:18
 Re: Parts Lists in reply to Bob (Aust), 05-31-2007 20:53:16
Outside under the gray and various colours , on the engine, bottom mostly.
