re: Dead cylinder - stuck valve?
IMPCON
05-29-2007 16:19:11
I finally drove my TEA 20 out of the shop under it's own power - sort of. I needed to put it outside to make room in the shop for more pressing matters. It had sat for a number of years and the engine would not turn over all the way when I first brought it home. It would turn part of a turn then sem to meet resistance and you could move the crankshaft back to where it would again meet resistance as if there was something on one of the cylinder walls like rust perhaps. After a liberal dosing of ATF, the engine was free and I have had it running. I checked the compression and got the following readings - #1 - 40lbs, #2 0 lbs, #3 - 110 lbs and #115 llbs. I know that there are numerous reasons that this could be but I wanted to know if the Standard engines have a habit of valves sticking when they sit? I have not pulled the valve cover off yet - just looking for some input. Thanks. gary
John(UK)
05-30-2007 13:51:55
 Re: re: Dead cylinder - stuck valve? in reply to IMPCON, 05-29-2007 16:19:11
The Standard engine doesn't have a "Habit" of the valves sticking but they can stick when not used for a long period just like any other engine. With compression readings so low, either the valves are burnt and allowing the gas to escape or they are simply not seating because they have been stuck with standing over a long period. No matter what, I would think that you should remove the Cylinder head and grind-in the valves again. If the two cylinders with low compression are next to each other like 1 & 2 or 3 & 4, it just could be the Head Gasket that has blown, but the only way to make sure is remove the Head and check it.
Jim W
05-30-2007 10:55:48
Shoot some oil in the cylinders and check compression again. If it goes up it's rings. if not, it's valves, or really bad rings. But you could learn something easily.
Next step, pull the gas tank and valve cover, have a look if everything is moving when you crank it.
Jim
Jerry/MT
05-29-2007 19:58:35
I presume that the engine was not at operating temperature when you did your compression check but you definetly have problems on cylinders #1 & #2. I have no specific experience with Standard Engines but the are just another overhead valve engine.
It is possible that some carbon is caught under a valve not allowing it to seat, or that an exhaust valve is burned. There is a possibility that the headgasket is also damaged between #1 and #2 since they are both low. The rings may also be stuck. Since the engine was stuck, you'll have to do some looking to sort out the problems because there is some inherent damage that occurs when that happens.
