Positive Ground on Ford/Ferguson
RKG
05-28-2007 10:10:37
My father and I recently bought a Ford 9N and a Ferguson TO-30 from a very reputable mechanic. The Fergie has been converted to 12V, the 9 is still original 6V. Although both received new batteries at the time of sale, I"m totally confused as to the wiring.
My Fergie has the Negative lead of the battery connected to the frame behind the dash, and the Positive cable runs down to a connection where the starter cable runs to the starter. Is this correct? It seems backward from the schematics I"ve been looking at. I"m pretty sure both tractors have the batteries hooked up the same.
Having said that, I have not had any problems with my 30 until this weekend when the starter will not turn. (It reads 12V when the starter is engaged, but nothing happens. I have taken it off and tried it with no luck. Probably needs a re-wire?). Dad has had some starting problems with his 9N (slow turnover, like a very weak battery). We have jumped the starter, as described in this forum to get it running, and it seems to run OK then, but very weak to start next time.
Any input or help with this would be greatly appreciated. Thanks
John(UK)
05-29-2007 11:30:41
 Re: Positive Ground on Ford/Ferguson in reply to RKG, 05-28-2007 10:10:37
I believe that the 6v Fords were positive ground and changed to negative when they changed to 12v. The Ferguson should be positive ground but very often when a new battery is fitted they fit them the wrong way around just because they are not used to these old machines and compare them to more modern vehicles. Move the ground lead from the back of the dash down to one of the bolts in the area of the starter, the dash will now be semi insulated from the tractor due to rusting and its age. People who have done this say that the tractor does run much better. The same will apply to the Ford if it is attached to the dash area, just move it to the area of the Starter it will be a much better connection anyway. This could account for it starting ok when you jump start it from another battery, it just isn't making a good connection from it's own battery and why it only turns over slowly.
RKG
05-29-2007 17:00:46
 Re: Positive Ground on Ford/Ferguson in reply to John(UK), 05-29-2007 11:30:41
Should I use the same gauge wire when I move the ground (0 or 00)? And, should I just connect it to one of the main bolts there or is there a specific place that is better than others?
John(UK)
05-30-2007 11:37:13
 Re: Positive Ground on Ford/Ferguson in reply to RKG, 05-29-2007 17:00:46
Use the same gauge of battery cable or even slightly heavier than the original. Connect it direct from the battery to one of the starter Mounting bolts or close to the Starter (engine to clutch housing) will do, anywhere other than the dash panel is better....John
RKG
05-30-2007 12:55:06
 Re: Positive Ground on Ford/Ferguson in reply to John(UK), 05-30-2007 11:37:13
Thank you. I appreciate the advice.
John(UK)
05-30-2007 13:24:59
 Re: Positive Ground on Ford/Ferguson in reply to RKG, 05-30-2007 12:55:06
Anytime at all..... John
Jerry/MT
05-28-2007 17:24:05
If your Ferguson has an alternator then the the ground must be negative because of the way the solid state regulator works. If the 9N has a 6V system with a generator, the grounding is from the positive battery terminal. You however state that you are "...pretty sure both tractors have the batteries hooked up the same." If that's true, you better get at least one of them hooked up right!
Regarding your TO-30, there are several reason's that the starter will not actuate. You could have a weak battery, corrosion on the battery terminals, damaged battery cable to switch, bad connection to the starter switch, bad starter switch, damaged starter switch cable to starter, bad connection to the starter,poor starter ground, and/or a bad starter.
Make sure the battery is fully charged. Then get a set of jumpers and connect the positive lead directly to the starter terminal. MAKING SURE THAT THE TRACTOR IS NOT IN GEAR, connect the negative lead to the negative battery terminal then touch the other end of the negative lead to the starter flange where it connects to the engine. The starter should turn the engine over. If it doen't the starter may need new brushes and/or a commutator cleaning. If the starter turns over, the connecting cables and the switch and the battery terminal connectios are suspect. The switch is adjustable so you can loosen the four nuts and slide it around until you get a good connection.
Regarding the 9N, make sure that the battery is hooked up correctly and the generator is polarized.(Short the armature connection on the generator to ground momentarily.) The 6V starters just naturally turn slower than the 12 V. if the battery is hooked up with the incorrect ground, then the coil does not have the correct polarity and the spark will be weak. The other thing to look for are the same things I mentioned above on the TO-30 viz. the cables to the starter and all the connections. The starter could also be bad. Run the same test as the TO-30 to isolate the connection from the starter. The 6V starters need big cables so you shouldn't have 4 gauge automobile starter cables on your 6V system. You need O or OO gauge cables.
Hope this helps you.
RKG
05-29-2007 02:19:35
 Re: Positive Ground on Ford/Ferguson in reply to Jerry/MT, 05-28-2007 17:24:05
Yes, it does help. I am very glad for those of you with the experience and expertise that are willing to share your knowledge with us "newbies".
I've gone thru all the procedures you have outlined with the starter, and am going to take it to a rebuild shop. I actually disassembled it..... .. and well, it needs some attention.
Hopefully, will get over to Dad's later today or tomorrow and investigate the 9N.
Thanks again for your input and insight.
Bob (Aust)
05-28-2007 13:38:25
If the battery negative goes to earth at the dash, sounds like the tractor as been converted to negative earth? If so, check the coil to make sure the leads have been swapped, + (pos) to ignition; - (neg) to distributor.
I suggest you take the earth lead off the back of the dash, clean it up and move to earth at the engine. The dash connection is notorious for a bad earth.
I think the wiring diagram is on this site in the Info Section (to the left), but if not, it is available from the FENA site.
rkg
05-28-2007 16:48:58
 Re: Positive Ground on Ford/Ferguson in reply to Bob (Aust), 05-28-2007 13:38:25
Thanks, I did check the FENA site and the wiring schematic for the 12V conversion does show the Neg being grounded, and well, the rest of the wiring pretty much like it is on the TO30. I will have to investigate the 9N, because I"m pretty sure that"s not right. I did find another post about polarizing the generator and the effects of having the battery hooked up wrong.
I"m gonna run the starter to the rebuild shop and see what they come up with. I have 12V on the starter when I engage the starter switch, but absolutely no response. Hopefully a quick rebuild will get me back in the field. Thanks for the reply.
