to35 charging
fergfan
05-27-2007 11:01:56
I can`t figure out why my tractor is not charging. I had the generator worked on three times and got a new voltage regulator. Replaced all wiring. Worked on all contact points.Help?
fergfan
05-28-2007 13:40:53
 Re: to35 charging in reply to fergfan, 05-27-2007 11:01:56
I have replaced the ampmeter.
Jerry/MT
05-27-2007 20:47:13
Did you polarize the generator after you installed it? To polarize your 6 volt positve ground generator, per the Shop Manual, momentarily connect a jumper between the armature connection of the generator and the negatve terminal of the battery.
fergfan
05-28-2007 05:19:24
 Re: to35 charging in reply to Jerry/MT, 05-27-2007 20:47:13
Yes I did polarize the generator.
Jerry/MT
05-28-2007 10:04:32
 Re: to35 charging in reply to fergfan, 05-28-2007 05:19:24
Have you considered the possibility that your ammeter may not be working?
Does it show a discharge when you turn on the lights without the motor running? Another way to check it is to make sure the points are closed and then turn on the key but don't start it. It should show a discharge. Do this monmentary so you don't overheat the coil.
