te20 brake lining kit
john [mo]
05-24-2007 20:15:22
i got the sparex brake lining kit today. i ran into a problem. the rivets are too long to tighten up the lining.i already cracked one lining in half before i figured out they were too long. now here is the question. are my shoes too thin,the linings too thin,or the rivets too long. my fix is to put some small washers that i had in my rivet gun kit under the brake shoe side before i peen the heads over. i tried one and it tightened up good. now i have to go buy about 50 of those little washers. sure wish i could find shoes with the linings already attached.i also got the shifter starter safety switch too. i had to make a new pin for linkage because the original was too short. i got that working good. i feel like when i used to buy a lot of aftermarket parts for my harley. always had to bend or grind or weld them to get those to work.
John(UK)
05-25-2007 07:39:46
 Re: te20 brake lining kit in reply to john [mo], 05-24-2007 20:15:22
Providing the linings hadn't worn away the shoes should not have been touched or worn in any way.
The linings could be too thin but the most likely cause is the rivets are too long. You should complain to Sparex, while it won't help you right now, it may help someone else in the future. There are two types of brakes fitted to these tractors, Sparex do complete brake shoes but they may be for the later type only S40825..MF 1810517M1..You are correct, it is so frustrating when you buy something and it doesn't fit like they say it will. Interesting about that Pin for the safety switch, I had never heard that before, thanks for that....John
john [mo]
05-25-2007 09:11:10
 Re: te20 brake lining kit in reply to John(UK), 05-25-2007 07:39:46
here is the switch part number i got from sparex.
S.42538
maybe i ordered the wrong one.been known to happen.it should be for a te20 with a continental engine.it does work perfectly now after i made my pin.i did not like the idea of standing next to the tractor and pushing a button to start.if it accidently was in gear could be painful. i will be going to the country this weekend so i will get more detailed pics of my to20 alternator install.
john [mo]
05-25-2007 09:22:55
 Re: te20 brake lining kit in reply to john [mo], 05-25-2007 09:11:10
the switch was for a TEA tractor. my mistake. but now i know it will work on to20 and te20 tractors.if you can make your own pin or go to hardware store and and find the right one.
John(UK)
05-25-2007 11:19:02
 Re: te20 brake lining kit in reply to john [mo], 05-25-2007 09:22:55
That switch (S42538)fits all TE20 series that includes TEA's too There is a switch for the TO20 part # S60821 its completely different to the TE20 type and it wont fit, but Sparex has it listed that it will fit, unless they supply some extra parts you can't fasten it to a TE20 series.
john [mo]
05-25-2007 18:54:30
 Re: te20 brake lining kit in reply to John(UK), 05-25-2007 11:19:02
ok well i guess if somebody orders one for their te20 they may read here that it will work even if they have to make or buy their own pin.
