Zane Thang Adjustment
Griz
05-21-2007 06:27:04
I would like to get more use out of my Thang. It doesn't hold position very well. When i set the heigth it slowly drops down and then raises quickly. The swing is about 4 to 6 inches. The bracket fit loosely on the lift arm so I ran a stainless steel clamp around it. It doesn't move on the lift arm any more. The problem still persists. Is it my tractor or is it somehow out of adjustment?
Thanks
Griz
gshadel
05-22-2007 14:14:56
 Re: Zane Thang Adjustment in reply to Griz, 05-21-2007 06:27:04
I have a thang also, and don't have that problem. Sounds like some sort of adjustment problem on your TO. I like John's idea on the quadrant. I also agree with John that the loose bracket sounds odd, mine is tight... I'm wondering if your thang may not be installed quite right by the prev. owner? Getting the instructions from Zane would probably be a good idea.
George
John (TR)
05-21-2007 19:08:04
I have one and it works great. Seems to me you have to adjust the quadrant first so that the movement of the arms happens in the first third of travel. thats adjusted by moving the quadrant front to back and a little movement makes a lot of difference.
I don't understand why it would be loose. I think there are 2 tabs and I squeezed mine together a little to take the play out
John(UK)
05-23-2007 11:08:55
 Re: Zane Thang Adjustment in reply to John (TR), 05-21-2007 19:08:04
The correct setting for the quadrant lever is that it should be in a neutral position at 2-1/2 from the top of the quadrant. Measure 2-1/2" from the front of the lever when it is in the maximum lift position and mark the quadrant. The back edge of the lever has to be on that mark when the quadrant is adjusted. At that point the lift arms should neither lift nor lower. It does have a reaction to the setting of the Hydraulic if this is incorrect and this can be caused by having too much play in the Draft Control spring, that should be set so you can just turn it by hand when you have an implement in the raised position. Just don't try to tighten it when it is seized up as it will twist or break something. The Draft Control Spring has to be set first then the Quadrant, no use trying it the other way around as altering the Spring alters the Quadrant lever adjustment.
Bruce(OR)
05-21-2007 07:27:41
My Zane Thang is sitting in the back room along with a stack of parts from the front axle to the rear PTO seal...Now to find the destructions...
The contact for Zane is "[email protected]"
or call 256 268 2327. That's down in Talladega, Alabama. Y'all have fun!
John(UK)
05-21-2007 06:59:38
It sounds like you have a leak on the Hydraulics on the tractor, the "thang" is working to try to correct it. If you need help with trying to find the leak that there must be, email me at:-
[email protected]
tell me again what the problem is so that I will remember it. I will send you the information you need with some pictures so you know what to look for....John
PS you don"t say what your tractor is or give a serial number, some faults need this info.
