cam bearings
david/co
05-17-2007 11:36:05
Does anybody know where I can get new bearings for the camshaft? Size needed etc.
Jim in OH
05-17-2007 11:50:41
 Re: cam bearings in reply to david/co, 05-17-2007 11:36:05
What tractor do you have? The TO-20 and TO-30 do not normally have cam bearing inserts (they run on the cast iron) unless it has been retro-fitted with aftermarket inserts.. Jim
david/co
05-17-2007 13:15:17
 Re: cam bearings in reply to Jim in OH, 05-17-2007 11:50:41
Jim, Thanks for your response! I have a TO 20 with a Z129. I posted a few months ago to try to determine if the Z129 was in fact the TO 30 block which was pretty much determined that it was. I think at some point the block was changed out.
John(UK)
05-17-2007 14:53:34
 Re: cam bearings in reply to david/co, 05-17-2007 13:15:17
you can get it line bored and bushed to fit your camshaft at a good machine shop. We have to do this to the Standard Engines too. You will have to have the bushes made to fit your block, ask for advice from the machine shop first, they may not be able to do it, but you should find someone.
Duner Wi
05-17-2007 19:14:56
 Re: cam bearings in reply to John(UK), 05-17-2007 14:53:34
Sealed Power list cam brg set #SH 683S for Z120-Z129. Maybe you won't have to make the bushes up.
John(UK)
05-18-2007 04:18:12
 Re: cam bearings in reply to Duner Wi, 05-17-2007 19:14:56
That looks interesting. tried to find it but couldn't, can you point me to the site that lists this plz. Thank you....John
Duner Wi
05-18-2007 05:24:35
 Re: cam bearings in reply to John(UK), 05-18-2007 04:18:12
I looked it up in my Sealed Power "Heavy Duty Engine Parts" catalog from about 20 years ago.
