Z120 head on Z129 block
david/co
05-17-2007 11:33:13
I ordered the comprhensive overhaul kit for a Z129. Upon receiving the kit I found the valves to have a larger head diameter than on the existing valves. The head is stamped Z120. Are the Z120 head interchangeable with the Z129 block? Must be as this tractor ran before I began the overhaul. Would I need to have Z129 pistons and sleeves and Z120 valves?
Jim in OH
05-17-2007 11:46:08
 Re: Z120 head on Z129 block in reply to david/co, 05-17-2007 11:33:13
You might search for previous posts on the same subject... The heads are certainly different (different part numbers), but the only difference in the heads that has been identified, as far as I know, is the valve size. And apparently yours is not the first Z129 to have a Z120 head... I think that the answers to your questions are yes and yes.. Jim
