TO-20 12V Conversion
Jim
01-26-2001 15:53:22
I recently converted my TO-20 to 12V. The ballast resistor I put in (1.2 ohm) doesn't drop the voltage down very much. Does anyone know what ballast resistor to use? After the conversion it started to miss under load. I don't know if its just conincidental or if it has to do with the conversion. Thanks for the help.
rick grant
02-20-2001 17:57:10
 Re: TO-20 12V Conversion in reply to Jim, 01-26-2001 15:53:22
after switching mine to 12volt i have to have brushes put in my starter about once a year any help
Joe in NY
01-27-2001 19:19:06
JIm,
I think this is the resistor from NAPA.
Its a Chrysler part and I think this is the part # NAPA #ICR13 Good luck,
Joe
Jim
01-28-2001 06:37:55
 Re: Re: TO-20 12V Conversion in reply to Joe in NY, 01-27-2001 19:19:06
That is the part number they gave me. I put it in and it seems to work fine. Had to replace the points, think I might have burned them using the other ballast resistor. Thanks for the help.
Jim
SandyB@TN
01-27-2001 12:28:44
Jim,
Go to an auto parts store and get the ballast resistor for a pre-76 Dodge. It'll do just fine.As for the miss under load, sounds like the high speed needle in your carburetor needs opening up a tweak. Get the tractor under a load and keep opening up about 1/8 turn at a time until it runs well with the load.
HTH
Sandy
Jim
01-27-2001 14:28:53
 Re: Re: TO-20 12V Conversion in reply to SandyB@TN, 01-27-2001 12:28:44
Sandy
Thanks for the info. I'll be working on it here shortly.
