Throttle link
dyt4000
05-14-2007 02:30:19
My link with between the lever and the disk has fallen off due to the balls rusting away. Does anyone have a good idea how to replace that setup?
dyt4000
05-15-2007 10:57:49
 Re: Throttle link in reply to dyt4000, 05-14-2007 02:30:19
You are the man! Here's my version...
third party image
third party image
third party image
Bob (Aust)
05-14-2007 03:23:05
My, my, your balls have rusted off? You really have a problem!
Convert to the simple, reliable TEA20 throttle link system - no balls to rust off!!
Send me an email and I'll send you the photos and dimensions. I also sent the photos and dimensions to John (UK) who could probably give you far more professionally competent advice!
Bob (Aust)
05-14-2007 03:25:42
 Re: Throttle link in reply to Bob (Aust), 05-14-2007 03:23:05
third party image
Having problems posting photos..... ...
Bob (Aust)
05-14-2007 03:27:42
 Re: Throttle link in reply to Bob (Aust), 05-14-2007 03:25:42
third party image
Pin on throttle lever.
Bob (Aust)
05-14-2007 03:28:52
 Re: Throttle link in reply to Bob (Aust), 05-14-2007 03:27:42
third party image
Pin on governor control rod...
Bob (Aust)
05-15-2007 18:15:10
 Re: Throttle link in reply to Bob (Aust), 05-14-2007 03:28:52
third party image
dyt4000. Looks perfect!
For interest, the correct "twist" angle is less than 90 degrees, maybe 75 to 80 degrees, see photo?
Your home made link appears to be a right angle "twist", 90 degrees.
Is the throttle free through it's entire travel?
Thanks Bob
dyt4000
05-15-2007 18:36:47
 Re: Throttle link in reply to Bob (Aust), 05-15-2007 18:15:10
It was at 90 degrees but I had to adjust it back some after installing it. Full throttle range is not a problem!
