TO-20 Crankshaft Pulley/Front Pump
Daniel W. Oehmk
05-11-2007 19:32:36
What way is the nut threaded, which holds the pulley on the front end of a TO-20 crankshaft? I need to get it off to put on a sheave for a front pump. Somewhere thought I heard recently about a Ford or Ferguson nut that was threaded to tighten counter clockwise??? Thanks! Dan
Dan Oehmke
05-12-2007 04:47:35
 Re: TO-20 Crankshaft Pulley/Front Pump in reply to Daniel W. Oehmke, 05-11-2007 19:32:36
I didn't see any locking tabs, so will take a closer look. I'm still looking for the right hub to take an adapter for the pump shaft. Checking out the info Bruce posted several days ago, but can only find the hub on line. Fellow at the local MF place recommended bringing in my original hub that's on now, so they can confirm which hub, adapter, shaft will work. He said it's no problem and there's a lot of options.
Bruce(OR)
05-12-2007 00:36:19
I am curious to see your front pump set up. I also have a TO-20 that has the same need.
KSTractor
05-11-2007 20:52:46
It has to tighten the way you would turn it with the crank to start it, clockwise.
Bob (Aust)
05-12-2007 04:07:38
 Re: TO-20 Crankshaft Pulley/Front Pump in reply to KSTractor, 05-11-2007 20:52:46
Have you flattened the lock tabs? Undo counter clockwise.
