Temp gauge not reading
Mick74
05-08-2007 17:32:32
I recently installed a temp. gauge on my 30, and it's not reading. In the proccess, I also installed a thermostat, as it did not have one when I took the upper rad. hose off. Is it possible that I installed it backwards? I refered to my manual, and thought I installed the thermostat as directed. Thanks for any help.
phil(va)
05-10-2007 08:15:15
 Re: Temp gauge not reading in reply to Mick74, 05-08-2007 17:32:32
What the others said. Thermostat goes into the top hose at the connection with the block with the bullet end aimed toward the radiator.
gshadel
05-09-2007 09:18:16
Mick, if you installed the temp. gauge backwards, your TO would overheat in about 5 minutes. If your TO isn't overheating, it's in right.
On the thermometer install, I'm assuming you installed a capilary style temp. probe in the threaded port on the side of the coolant manifold on top the engine? Jeff's right , check the probe in hot water. Boiling water should shoot the gauge right up to ~210 degrees. If you have a gauge with a green/red scale, that would probably be right close to the red.
If your thermostat is inop. & already stuck open, your engine will never heat-up to operating temperature. If you suspect the thermostat may not be working, you can check that by dropping it in a pan of hot water also. The thermo should be closed at room temp, and open ~180 -190 degrees. A candy thermometer in your pot of water helps dial-in the water temp for the test.
George
Jeff-oh
05-09-2007 06:13:14
It is possible to install the therostats backwards.
the words "to Rad" and an arrow are imprinted on the thermostat did you check that?
But before you pull every thing apart, pull out the temp probe and tape the hole, as to not loose too much rad. fluid.
Put the probe in a pot and heat to boiling and see if the guage works. If you have a camp stove you may not even have to remove the gauge from the tractor.
Gauges can be bad too. Check the easy stuff first.
Mick74
05-12-2007 18:18:54
 Re: Temp gauge not reading in reply to Jeff-oh, 05-09-2007 06:13:14
Thanks all, Thermostat was in correctly, temp gauge no good. Appreciate the help.
