TO 20 electrical
mike glenn
05-08-2007 17:16:58
Hello, i have had some good help here, now we are stuck getting the voltage right to the distributor& coil. ----the tractor has not been converted to 12 volt!
---we have 6.2 volts to the coil with points open, ---but when points closed, instead of zero, we have 2.3 - 4. volts -so we are stuck there
thanks
Jim in OH
05-08-2007 20:17:30
 Re: TO 20 electrical in reply to mike glenn, 05-08-2007 17:16:58
Since you said 6 volt, I am going to presume that there is no ballast resistor to the coil... That being the case, you have either too much resistance in the line from the ignition to the coil (bad connections, corrosion, frayed wires, or a ballast resistor that should not be there, etc.) or your coil has too little resistance (i.e., internal short) and is drawing far too much current.... My money is on the first cause,... Jim
