To-30 motor
mark
01-23-2001 14:26:25
I have a to-30 backhoe the other day I was digging a hole and the water hose busted .I did not see it intill it got over heated.Now I have water in the oil.I have read some discussion on the page adout this topic and it seems to me that everybody ends up with a cracked block .Is this common for a to-30 to crack a block when it over heats and not warp the head.
ErnieD
01-27-2001 18:17:50
 Re: to-30 motor in reply to mark, 01-23-2001 14:26:25
We over heated a to 30 and it was a warped head. Put a straight edge front to back to check yours out. Be sure to remove the thermostat gasket when you have it planed. We squared it up and it worked fine.
dennis
01-23-2001 14:51:01
If I was to guess, I'd say the head would be more likely to warp first based on other engines I've done over. I ohauled my TO-30 several years ago and fortunately I haven't had a problem with either head or cracked blocks - yet.
