TE-20 12 volt wiring
Danny Wendt
04-29-2007 18:20:10
My 1948 TE-20 keeps burning up or ruining solinoids. Its wired according to a diagram on the internet. It starts and runs fine when I bypass the solinoid. Any advise would be appriciated. Thnks
Daniel Collings
05-01-2007 20:50:33
 Re: TE-20 12 volt wiring in reply to Danny Wendt, 04-29-2007 18:20:10
Burning up solenoids?.....the TO-20 didn't have a solenoid. It has something that looks like a solenoid. It only had two wires. One from the battery and one to the starter. Is this what you are talking about?
Jerry/MT
05-01-2007 22:14:42
 Re: TE-20 12 volt wiring in reply to Daniel Collings, 05-01-2007 20:50:33
It actually has a wire from the battery to the transmission lever actuated switch, and another wire from the switch to the starter. The starter housing is grounded to the tractor to complete the circuit.
Jerry/MT
04-29-2007 19:45:41
You know we're not mind readers. You say that your tractor ".. is wired according to a diagram on the internet." That covers a lot of ground. You surely can't expect us to know which wiring diagram you used!
The TE-20 as it came originally didn't have a solenoid. It had a safety switch that was actuated through the transmission shift lever that functioned as the starter actuator and a safety switch. Maybe you should convert your tractor back to its original configuration. There is a diagram at www.fergusonenthusiasts.com
