What is this?
Indiana Jones
04-28-2007 18:03:23
While scraping crud off my TO 30 getting it ready for paint I noticed a small adjusting screw coming from the front engine cover. It points toward the left near the radiator hose. Anyone know what it is? It looks like a long carb adjusting screw - spring and all.
Bob (Aust)
04-29-2007 14:19:23
 Re: What is this? in reply to Indiana Jones, 04-28-2007 18:03:23
third party image
I've never seen a TO30 - I don't think there are any in Australia - so I'm only guessing. Continental engine Fergys were never imported here.
But if your screw is in the side of the timing case it's a fair bet it will be associated with the governor, which is on the front of the cam shaft gear.
Here's the timing cover off my TEA20. Top right is the "bumper adjusting screw". I THINK your engine is similar. (The Standard engine uses a timing chain. I suspect the Continental engine has a gear driven cam shaft?)
Someone here should know.
Jerry/MT
04-29-2007 14:52:39
 Re: What is this? in reply to Bob (Aust), 04-29-2007 14:19:23
Bob's right it's the governor adjusting screw or damper. If you have a "galloping rpm" you screw it in just enough to stop it. It damps the speed variation.
Indiana Jones
04-29-2007 06:54:23
Bob, thanks for the reply. I'll have to invest in some literature. I just recently bought the tractor, and it is my first Ferguson.
By the way, I didn't mean to imply that I thought it might be a carb adjusting screw - only that it LOOKS like a carb adjusting screw!
Bob (Aust)
04-28-2007 18:43:34
Don't know the TO30 but if similar to the TEA20, it sounds like the bumper adjusting screw for the governor, which screws into the front engine timing case, on the left, near the radiator hose?
Buy a workshop manual. Best investment you'll ever make.
